Nintendo GameCube Controller Triggers Replacement
  1. Nintendo GameCube Controller Triggers Replacement, Back Panel: step 1, image 1 of 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Ask FixBot
  2. Nintendo GameCube Controller Triggers Replacement: step 2, image 1 of 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Ask FixBot
  3. Nintendo GameCube Controller Triggers Replacement, Z Button: step 3, image 1 of 2 Nintendo GameCube Controller Triggers Replacement, Z Button: step 3, image 2 of 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Ask FixBot
  4. Nintendo GameCube Controller Triggers Replacement, Circuit Board: step 4, image 1 of 1
    • Carefully unhook the cable that is looped around the peg.
    Ask FixBot
  5. Nintendo GameCube Controller Triggers Replacement: step 5, image 1 of 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Ask FixBot
  6. Nintendo GameCube Controller Triggers Replacement, Triggers: step 6, image 1 of 1
    • Remove the two 8.9mm Phillips Head #0 screws.
    Ask FixBot
  7. Nintendo GameCube Controller Triggers Replacement: step 7, image 1 of 1
    • Remove black cover.
    Ask FixBot
  8. Nintendo GameCube Controller Triggers Replacement: step 8, image 1 of 3 Nintendo GameCube Controller Triggers Replacement: step 8, image 2 of 3 Nintendo GameCube Controller Triggers Replacement: step 8, image 3 of 3
    • To remove the trigger assembly, depress the trigger with your index finger as if you are using the controller normally.
    • Hold the grey square bracket onside of the controller with your thumb.
    • Keep your fingers in the same place while rotating upwards towards you to remove trigger assembly.
    Ask FixBot
  9. Nintendo GameCube Controller Triggers Replacement: step 9, image 1 of 1
    • Pull the metal clip from the trigger.
    Ask FixBot
In order to remove the other trigger, simply repeat Steps 6 through Step 9 on the right side.
13 other people completed this guide.
Sean Michel
2,750 Reputation
8 Guides authored
Cal Poly, Team 19-44, Regan Winter 2013 Member of Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Members
34 Guides authored
3 Guide Comments
Don't forget to aline the trigger slider holes and the slider pins on the board when putting it all back together.
buttpug - Reply Share
Hallo ich habe da mal eine Frage. Ist es möglich die Empfindlichkeit der Trigger zu beeinflussen ? Leider reagieren sie erst sehr spät da mann den Knopf sehr weit hereindrücken muss.
danke schon mal
Otti
Ottitrotti - Reply Share
The trigger slider hole doesn’t sit well on the slider pins any suggestions ?
cHiLLz747 - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 149
All Time: 30,636
