Shop the Holiday Gift Guide
Epson VS250 Shell Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
4
All Time:
124
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite Only.
Tools
    1. Epson VS250 Shell Replacement, Shell: step 1, image 1 of 1
      • Place the projector on a flat surface.
      • Orient the projector so that the the word "Epson" is facing you.
      • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
      Ask FixBot
    2. Epson VS250 Shell Replacement: step 2, image 1 of 1
      • Slide the cover to the right and lift the cover up and out to remove.
      Ask FixBot
    3. Epson VS250 Shell Replacement: step 3, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
      • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
      Ask FixBot
    4. Epson VS250 Shell Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
      Ask FixBot
    5. Epson VS250 Shell Replacement: step 5, image 1 of 2 Epson VS250 Shell Replacement: step 5, image 2 of 2
      • Flip the projector so that it lays upside down.
      • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
      Ask FixBot
    6. Epson VS250 Shell Replacement: step 6, image 1 of 1
      • Remove the front cover from the projector by pulling it off of the device.
      Ask FixBot
    7. Epson VS250 Shell Replacement: step 7, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
      • After completing this step you will be able to remove the back cover from the projector.
      Ask FixBot
    8. Epson VS250 Shell Replacement: step 8, image 1 of 1
      • Slowly lift up the top shell up and out of the device.
      • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
      Ask FixBot
Author
with
Justin Ogihara
31,752 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 124
