Installing Epson Stylus Photo 820 Ink Cartridges
  1. Installing Epson Stylus Photo 820 Ink Cartridges, Ink Cartridges: step 1, image 1 of 1
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Installing Epson Stylus Photo 820 Ink Cartridges: step 2, image 1 of 2 Installing Epson Stylus Photo 820 Ink Cartridges: step 2, image 2 of 2
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Installing Epson Stylus Photo 820 Ink Cartridges: step 3, image 1 of 2 Installing Epson Stylus Photo 820 Ink Cartridges: step 3, image 2 of 2
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Installing Epson Stylus Photo 820 Ink Cartridges: step 4, image 1 of 3 Installing Epson Stylus Photo 820 Ink Cartridges: step 4, image 2 of 3 Installing Epson Stylus Photo 820 Ink Cartridges: step 4, image 3 of 3
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Installing Epson Stylus Photo 820 Ink Cartridges: step 5, image 1 of 3 Installing Epson Stylus Photo 820 Ink Cartridges: step 5, image 2 of 3 Installing Epson Stylus Photo 820 Ink Cartridges: step 5, image 3 of 3
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
Alex Lin
99 Reputation
3 Guides authored
Cal Poly, Team 20-68, Walters Spring 2011 Member of Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 2,898
