Epson Powerlite 410W Lens Replacement
    1. Epson Powerlite 410W Lens Replacement, Top Cover: step 1, image 1 of 1
      • Press the power button located on top of the projector.
      • Remember to let the projector cool off completely after turning off the power before beginning the repair.
      Ask FixBot
    2. Epson Powerlite 410W Lens Replacement: step 2, image 1 of 1
      • Remove eight screws from the bottom of the device using a Phillips #00 screwdriver.
      Ask FixBot
    3. Epson Powerlite 410W Lens Replacement: step 3, image 1 of 3 Epson Powerlite 410W Lens Replacement: step 3, image 2 of 3 Epson Powerlite 410W Lens Replacement: step 3, image 3 of 3
      • Turn the projector so the power button is on top.
      • Gently pull up the cover until it pops off.
      • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
      • Disconnect the ribbon cable that attaches the cover to the motherboard.
      • Remove the cover and place to the side.
      Ask FixBot
    1. Epson Powerlite 410W Lens Replacement, Motherboard: step 4, image 1 of 2 Epson Powerlite 410W Lens Replacement, Motherboard: step 4, image 2 of 2
      • Remove the two screws holding down the motherboard using a Phillips #00 screwdriver.
      • Remove the four screws holding down the I/O board using a Phillips #00 screwdriver.
      Ask FixBot
    2. Epson Powerlite 410W Lens Replacement: step 5, image 1 of 1
      • Remove the seven cables that are running to the motherboard by pulling them out of their sockets.
      Ask FixBot
    3. Epson Powerlite 410W Lens Replacement: step 6, image 1 of 3 Epson Powerlite 410W Lens Replacement: step 6, image 2 of 3 Epson Powerlite 410W Lens Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Using a plastic opening tool, gently pry up the black tabs holding in the ribbon cables on the motherboard.
      • Using tweezers, gently pull the ribbon cables out of the sockets.
      Ask FixBot
    4. Epson Powerlite 410W Lens Replacement: step 7, image 1 of 1
      • Gently pull the motherboard up and tilt it back, revealing the last cable attached to the motherboard. Disconnect this cable.
      • Remove the motherboard from the projector.
      Ask FixBot
    1. Epson Powerlite 410W Lens Replacement, Lens: step 8, image 1 of 2 Epson Powerlite 410W Lens Replacement, Lens: step 8, image 2 of 2
      • Remove four 2.5 mm silver hex screws from the silver bracket.
      • Depending on your screwdriver size, a flexible bit extension may be required.
      Ask FixBot
    2. Epson Powerlite 410W Lens Replacement: step 9, image 1 of 2 Epson Powerlite 410W Lens Replacement: step 9, image 2 of 2
      • Remove the four silver screws from the base of the lens.
      Ask FixBot
    3. Epson Powerlite 410W Lens Replacement: step 10, image 1 of 2 Epson Powerlite 410W Lens Replacement: step 10, image 2 of 2
      • Pull the lens assembly out from the silver bracket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 31
All Time: 570
