Epson PowerLite 77c Top Panel Replacement
    1. Epson PowerLite 77c Top Panel Replacement, Top Panel: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
      • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
      • Lift the top panel up.
      • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
      Ask FixBot
    2. Epson PowerLite 77c Top Panel Replacement: step 2, image 1 of 2 Epson PowerLite 77c Top Panel Replacement: step 2, image 2 of 2
      • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
      • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
      • Remove the top panel.
      Ask FixBot
Connor Bassolino
26,043 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 58
All Time: 258
