Epson PowerLite 77c Lamp Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
20
Past 30 Days:
57
All Time:
644
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide demonstrates how to replace an Epson PowerLite 77c (V11H254220) lamp, part number V13H010L41. The projection lamp is the heart of a projector, as it lights and displays images. If you're experiencing issues involving a dim image, or if the lamp isn't illuminating at all when the projector is on, it's probably time to replace the lamp. Issues with the lamp are typically indicated by a flashing orange light under the power button.
There is mercury in the device’s lamp; therefore, there are state and local regulations regarding disposal and recycling. Do not discard in the trashcan.
Before removing the lamp, be sure power down and unplug the device; allow it to fully cool before beginning.
Parts
Tools
    1. Epson PowerLite 77c Lamp Replacement, Lamp: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
      Ask FixBot
    2. Epson PowerLite 77c Lamp Replacement: step 2, image 1 of 1
      • Slide the cover toward you, then lift it to remove it.
      Ask FixBot
    3. Epson PowerLite 77c Lamp Replacement: step 3, image 1 of 2 Epson PowerLite 77c Lamp Replacement: step 3, image 2 of 2
      • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
      • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
      • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 57
All Time: 644
