Epson PowerLite 77c Fan Replacement
    1. Epson PowerLite 77c Fan Replacement, Lamp: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
      Ask FixBot
    2. Epson PowerLite 77c Fan Replacement: step 2, image 1 of 1
      • Slide the cover toward you, then lift it to remove it.
      Ask FixBot
    3. Epson PowerLite 77c Fan Replacement: step 3, image 1 of 2 Epson PowerLite 77c Fan Replacement: step 3, image 2 of 2
      • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
      • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
      • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
      Ask FixBot
    1. Epson PowerLite 77c Fan Replacement, Fan: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
      • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
      • Lift the top panel up.
      • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
      Ask FixBot
    2. Epson PowerLite 77c Fan Replacement: step 5, image 1 of 2 Epson PowerLite 77c Fan Replacement: step 5, image 2 of 2
      • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
      • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
      • Remove the top panel.
      Ask FixBot
    3. Epson PowerLite 77c Fan Replacement: step 6, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 5.0 mm screws.
      Ask FixBot
    4. Epson PowerLite 77c Fan Replacement: step 7, image 1 of 2 Epson PowerLite 77c Fan Replacement: step 7, image 2 of 2
      • Remove the one 5.0 mm screw on the right side of the gap with a Phillips #0 screwdriver.
      • Remove the one 5.0 mm screw on the left side of the gap with a Phillips #0 screwdriver.
      Ask FixBot
    5. Epson PowerLite 77c Fan Replacement: step 8, image 1 of 1
      • On the right side of the motherboard, grip the plug labeled "PWR-FAN" and pull straight up to detach the fan from the motherboard.
      Ask FixBot
    6. Epson PowerLite 77c Fan Replacement: step 9, image 1 of 2 Epson PowerLite 77c Fan Replacement: step 9, image 2 of 2
      • Grip the fan and lift it up and out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 50
All Time: 443
