Shop the Holiday Gift Guide
Epson ET-2750 error message 034004
Views: 54K
View statistics:
Past 24 Hours:
52
Past 7 Days:
253
Past 30 Days:
1,247
All Time:
53,694
Comments: 26
13 comments on steps, 13 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to fix error code 034004 on your Epson ET-2750 printer. This error is often incorrectly displayed as a paper jam, although there is no paper jam. You can rectify the error with simple mechanical interventions.
    1. Epson ET-2750 error message 034004, Preparation: step 1, image 1 of 2 Epson ET-2750 error message 034004, Preparation: step 1, image 2 of 2
      • Switch off the printer and disconnect the power plug to avoid electric shock.
      • Open the printers front cover by lifting it up.
      Ask FixBot
    2. Epson ET-2750 error message 034004, Checking the print head position: step 2, image 1 of 1
      • Verify that the print head is on the right side of the printer. If not, the printer has not completed its job and the error is still present.
      Ask FixBot
    3. Epson ET-2750 error message 034004, Moving the gears manually: step 3, image 1 of 1
      • The print head must be moved to approximately the center, or briefly switch on the printer and disconnect it from the power supply as soon as the head is in the center.
      • Check the printer on the right-hand side, where the print head should normally be. You can now see white cogwheels at the bottom right.
      • Turn the middle gear wheel carefully with a wooden stick about one turn further. Turn the cogwheel on the upper side a few teeth backwards.
      Ask FixBot
    4. Epson ET-2750 error message 034004, Restart the printer: step 4, image 1 of 1
      • Close the printer cover.
      • Reconnect the printer to the power supply and turn it on.
      Ask FixBot
    5. Epson ET-2750 error message 034004, Error check: step 5, image 1 of 1
      • After the boot process, the print head should move all the way to the right to its start position and the error should be corrected. Why did this error occur?...maybe the last paper was pulled out too quickly
      Ask FixBot
This error can occur if printed paper is pulled out too quickly or if the printer has collected dust. Regular cleaning can help to avoid such problems.
***Happy Repairing!
Repair Cafes: Heidenheim + Birkenried
9 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Ferdinand
217 Reputation
1 Guide authored
13 Guide Comments
Et 2856
Erreur 034004
Imprimante quasi neuve
Papier normal
Tout été ouvert et vérifié : aucun papier déchiré , j ai meme enlevé les poussières 🙄
À plusieurs reprises a été éteint et rallumé
Ça ne fonctionne pas. Que faire ? Dois je la ramèner ????
Brigitte CLENET - Reply Share
Aucun résidu de papier n'a été trouvé à l'avant et à l'arrière.
Dans ce cas, veuillez procéder comme suit : (d'abord mettre hors tension !!)
Ouvrir l'imprimante à l'avant, c'est-à-dire soulever le couvercle. La tête d'impression doit se trouver sur le côté droit. Si ce n'est pas le cas, cela signifie que l'appareil n'a pas terminé son travail.
En bas à droite (où la tête devrait normalement se trouver), on voit trois roues dentées blanches qui assurent mécaniquement le transport du papier et de la tête d'impression. On peut facilement tourner la plus grande roue dentée avec le doigt ou avec un bâton de bois un peu plus loin (environ un tour maximum) - côté supérieur vers l'arrière. Cela devrait suffire.
Refermez le tout et mettez l'imprimante en marche. Le mécanisme devrait maintenant terminer l'intervalle et la tête d'impression devrait revenir à sa position initiale, tout à fait à droite. Dans ce cas, le message d'erreur ne devrait plus apparaître.
Pourquoi cette erreur s'est-elle produite... Peut-être qu'un pap
Ferdinand - Reply Share
Les roues dentées refusent de bouger. Que faire?
Mouchka Galvez - Reply Share
Essaie de tourner l'engrenage dans la direction opposée. si ça ne marche pas, regarde s'il est possible de déplacer la tête vers la droite avec la main, même si ce n'est qu'un peu. Ensuite, remets-la en marche. les engrenages doivent!! en tout cas bouger, sinon elle se bloque un peu, comme du papier. Je ne peux plus imaginer autre chose. bonne chance.
Possibilité également qu'il y ait un bourrage papier derrière l'imprimante et le bac de chargement du dessus. Pour cela, appuyer simultanément sur les 2 bouton gris à l'arrière de l'appareil. Cela permet de retirer le bac papier et d'accéder à l'endroit ou passe le papier. Retirer la feuille ou le bout de papier coincé.
laguille - Reply Share
Past 24 Hours: 52
Past 7 Days: 253
Past 30 Days: 1,247
All Time: 53,694
