Epomaker Shadow-X Switch Plate Re-alignment
    1. Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: step 1, image 1 of 3 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: step 1, image 2 of 3 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: step 1, image 3 of 3
      • Power off the keyboard and disconnect any USB cable.
      • Place the keyboard on a clean, static-free workspace.
      Ask FixBot
    2. Epomaker Shadow-X Switch Plate Re-alignment: step 2, image 1 of 1
      • Use a keycap puller/spudger to remove all keycaps on the keyboard.
      Ask FixBot
    3. Epomaker Shadow-X Switch Plate Re-alignment: step 3, image 1 of 1
      • Remove the screws on the back of the keyboard with a hex screwdriver.
      • Carefully pry open the case using a plastic opening tool or spudger, and separate the top and bottom halves.
      Ask FixBot
    4. Epomaker Shadow-X Switch Plate Re-alignment: step 4, image 1 of 1
      • Locate the switch plate, which sits between the key switches and the PCB.
      • If the switch plate is misaligned, carefully adjust it so that it sits flush and aligns with all switch positions.
      • Ensure that each switch slot in the plate lines up with the PCB holes below it.
      Ask FixBot
    5. Epomaker Shadow-X Switch Plate Re-alignment: step 5, image 1 of 1
      • If the plate has screws or clips, check that each one is correctly fastened to prevent future misalignment.
      • Gently press on different sections of the plate to verify that it’s stable and correctly positioned over the PCB.
      Ask FixBot
    6. Epomaker Shadow-X Switch Plate Re-alignment: step 6, image 1 of 3 Epomaker Shadow-X Switch Plate Re-alignment: step 6, image 2 of 3 Epomaker Shadow-X Switch Plate Re-alignment: step 6, image 3 of 3
      • Reinsert each switch, ensuring that they align with both the switch plate and the PCB.
      • Snap the top and bottom halves of the case back together. Replace and tighten all screws.
      • Reinstall all keycaps and check that they are aligned and consistent in height.
      Ask FixBot
You have successfully realigned the switch plate on your Epomaker Shadow-X keyboard! This adjustment improves switch stability and typing consistency. Check each key to confirm the alignment, and enjoy smoother, more consistent typing.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 377
