Enabot EBO SE Camera Replacement
    1. Enabot EBO SE Camera Replacement, Wheel Assembly: step 1, image 1 of 1
      • Gently turn the robot upside down.
      • Place the robot on a stable surface to prevent it from rolling or falling.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 2, image 1 of 3 Enabot EBO SE Camera Replacement: step 2, image 2 of 3 Enabot EBO SE Camera Replacement: step 2, image 3 of 3
      • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
      • A tool should have been provided in the box for this purpose.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 3, image 1 of 2 Enabot EBO SE Camera Replacement: step 3, image 2 of 2
      • Pull the wheel assembly towards you so it comes straight off without resistance.
      • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
      Ask FixBot
    1. Enabot EBO SE Camera Replacement, Lower Housing: step 4, image 1 of 2 Enabot EBO SE Camera Replacement, Lower Housing: step 4, image 2 of 2
      • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 5, image 1 of 3 Enabot EBO SE Camera Replacement: step 5, image 2 of 3 Enabot EBO SE Camera Replacement: step 5, image 3 of 3
      • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
      • Keep the Micro SD Card in a safe spot for later.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 6, image 1 of 2 Enabot EBO SE Camera Replacement: step 6, image 2 of 2
      • Place the iFixit opening tool inside the Micro SD slot.
      • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
      Ask FixBot
    4. Enabot EBO SE Camera Replacement: step 7, image 1 of 3 Enabot EBO SE Camera Replacement: step 7, image 2 of 3 Enabot EBO SE Camera Replacement: step 7, image 3 of 3
      • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
      • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
      Ask FixBot
    5. Enabot EBO SE Camera Replacement: step 8, image 1 of 3 Enabot EBO SE Camera Replacement: step 8, image 2 of 3 Enabot EBO SE Camera Replacement: step 8, image 3 of 3
      • There are two black and red wire connectors attached to the upper and lower housing.
      • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
      Ask FixBot
    1. Enabot EBO SE Camera Replacement, Motherboard: step 9, image 1 of 2 Enabot EBO SE Camera Replacement, Motherboard: step 9, image 2 of 2
      • Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 10, image 1 of 2 Enabot EBO SE Camera Replacement: step 10, image 2 of 2
      • Use the iFixit opening tool to unlock the middle gray tab and free the orange & black ribbon cable.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 11, image 1 of 3 Enabot EBO SE Camera Replacement: step 11, image 2 of 3 Enabot EBO SE Camera Replacement: step 11, image 3 of 3
      • Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
      • Place one finger in between the motherboard and the upper casing.
      • Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
      Ask FixBot
    4. Enabot EBO SE Camera Replacement: step 12, image 1 of 3 Enabot EBO SE Camera Replacement: step 12, image 2 of 3 Enabot EBO SE Camera Replacement: step 12, image 3 of 3
      • Use the ifixit opening tool to disconnect the blue & white ribbon cable.
      • Gently pull the blue & white ribbon cable out of the gray connector tab.
      Ask FixBot
    1. Enabot EBO SE Camera Replacement, Camera: step 13, image 1 of 3 Enabot EBO SE Camera Replacement, Camera: step 13, image 2 of 3 Enabot EBO SE Camera Replacement, Camera: step 13, image 3 of 3
      • Use a Phillips #00 screwdriver to remove all five 7.4 mm screws from the upper casing.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 14, image 1 of 2 Enabot EBO SE Camera Replacement: step 14, image 2 of 2
      • Place your fingers in the space between the black casing and white lid.
      • Pull black casing towards you to separate the two parts.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 15, image 1 of 3 Enabot EBO SE Camera Replacement: step 15, image 2 of 3 Enabot EBO SE Camera Replacement: step 15, image 3 of 3
      • Remove the two 6 mm Phillips #00 screws on either side of the camera.
      Ask FixBot
    4. Enabot EBO SE Camera Replacement: step 16, image 1 of 3 Enabot EBO SE Camera Replacement: step 16, image 2 of 3 Enabot EBO SE Camera Replacement: step 16, image 3 of 3
      • Gently remove the camera until it comes out of the casing.
      Ask FixBot
Oscar Parra
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 44
All Time: 685
