Eluktronics N850HK SSD Replacement
  1. Eluktronics N850HK SSD Replacement, SSD: step 1, image 1 of 3 Eluktronics N850HK SSD Replacement, SSD: step 1, image 2 of 3 Eluktronics N850HK SSD Replacement, SSD: step 1, image 3 of 3
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: step 2, image 1 of 2 Eluktronics N850HK SSD Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: step 3, image 1 of 2 Eluktronics N850HK SSD Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: step 4, image 1 of 2 Eluktronics N850HK SSD Replacement: step 4, image 2 of 2
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: step 5, image 1 of 3 Eluktronics N850HK SSD Replacement: step 5, image 2 of 3 Eluktronics N850HK SSD Replacement: step 5, image 3 of 3
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: step 6, image 1 of 3 Eluktronics N850HK SSD Replacement: step 6, image 2 of 3 Eluktronics N850HK SSD Replacement: step 6, image 3 of 3
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: step 7, image 1 of 3 Eluktronics N850HK SSD Replacement: step 7, image 2 of 3 Eluktronics N850HK SSD Replacement: step 7, image 3 of 3
    • Reassemble by following the directions in reverse order.
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
4 other people completed this guide.
Brandon Yuan
226 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 74
Past 30 Days: 375
All Time: 4,337
