Up to 20% off select tools
Electrical Wall Outlet Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
13
All Time:
1,404
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Tools
Introduction
Go to step 1 ↓
Broken outlets are a very common problem in many households and can be fixed in a few short steps. Outlets are used by everyone in all households for common every day things such as cooking, getting ready, and cleaning. Broken outlets can create hazards in homes due to exposing electrical wires that can cause fires. (Staff, 2011)
    1. Electrical Wall Outlet Replacement, Wall Outlet: step 1, image 1 of 2 Electrical Wall Outlet Replacement, Wall Outlet: step 1, image 2 of 2
      • Turn off electrical power from the breaker by switching off the breaker that is connected to the designated area.
      • Check power by plugging in rechargeable device and check if charging. If not charging, power to the wall is off.
      Ask FixBot
    2. Electrical Wall Outlet Replacement: step 2, image 1 of 1
      • Remove the screw from the outlet plate using a flathead screwdriver.
      Ask FixBot
    3. Electrical Wall Outlet Replacement: step 3, image 1 of 1
      • Remove plate from outlet using a Phillips screwdriver.
      Ask FixBot
    4. Electrical Wall Outlet Replacement: step 4, image 1 of 1
      • Remove screws from outlet that are connected to the wall using a Phillips screwdriver.
      Ask FixBot
    5. Electrical Wall Outlet Replacement: step 5, image 1 of 1
      • Remove wires from outlet by gently pulling them out of the outlet and wall.
      Ask FixBot
    6. Electrical Wall Outlet Replacement: step 6, image 1 of 2 Electrical Wall Outlet Replacement: step 6, image 2 of 2
      • Connect wires to new outlet being sure to connected them to their designated port. They are labeled on the back of the outlet with: neutral, ground and hot.
      • Insert wire into the designated port and tighten with Phillips Screwdriver.
      • Neutral Wire- White
      • Ground Wire- Copper
      • Hot Wire- Black
      Ask FixBot
    7. Electrical Wall Outlet Replacement: step 7, image 1 of 3 Electrical Wall Outlet Replacement: step 7, image 2 of 3 Electrical Wall Outlet Replacement: step 7, image 3 of 3
      • Reassemble the outlet as it was removed.
      Ask FixBot
5 other people completed this guide.
Author
with
Allison Novelli
107 Reputation
1 Guide authored
Texas Tech, Team 22-4, Rauch Spring 2016 Member of Texas Tech, Team 22-4, Rauch Spring 2016
TTU-RAUCH-S16S22G4
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,404
