Electrical Plug Replacement
Views: 56K
View statistics:
Past 24 Hours:
14
Past 7 Days:
121
Past 30 Days:
496
All Time:
56,413
Comments: 9
2 comments on steps, 7 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 27
27 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A common issue with electronic devices is a severed or damaged wire. Whether a dog chews through a wire, a child playing with scissors cuts a wire, or a large appliance slices through a wire, many have encountered this problem. This guide teaches how to remove a damaged plug and replace it with a new plug. The wiring in the lamp plug must be done correctly in order for the lamp to turn on after the repair is finished. This guide shows how to properly locate the "hot" and "neutral" connections.
Parts
Tools
    1. Electrical Plug Replacement, Two-Pole Plug: step 1, image 1 of 2 Electrical Plug Replacement, Two-Pole Plug: step 1, image 2 of 2
      • Be sure to unplug the lamp.
      • Locate the damaged portion of wire.
      • Cut the damaged plug from the lamp cord one inch below the damaged area
      Ask FixBot
    2. Electrical Plug Replacement: step 2, image 1 of 2 Electrical Plug Replacement: step 2, image 2 of 2
      • Separate the wire by gently pulling it apart.
      • The wire with the raised ribbing on the coating is the neutral wire.
      • The hot wire has a smooth coating.
      Ask FixBot
    3. Electrical Plug Replacement: step 3, image 1 of 3 Electrical Plug Replacement: step 3, image 2 of 3 Electrical Plug Replacement: step 3, image 3 of 3
      • Strip the coating off the wire.
      • Expose 3/4" of the copper wire.
      • Twist the exposed copper wire so that there is no fraying.
      • Twisting the wires ensures the strongest connection and maximum safety.
      Ask FixBot
    4. Electrical Plug Replacement: step 4, image 1 of 2 Electrical Plug Replacement: step 4, image 2 of 2
      • Loosen the screw and open the replacement plug.
      • The silver screw is the neutral connection, and the brass screw is the hot connection.
      • The different connections must be determined in order to properly wire the replacement plug.
      Ask FixBot
    5. Electrical Plug Replacement: step 5, image 1 of 3 Electrical Plug Replacement: step 5, image 2 of 3 Electrical Plug Replacement: step 5, image 3 of 3
      • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
      • Remember the neutral wire is the wire with raised ribbing on the coating.
      • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
      Ask FixBot
    6. Electrical Plug Replacement: step 6, image 1 of 2 Electrical Plug Replacement: step 6, image 2 of 2
      • Thread the cord so the plug will completely close.
      • Tighten the exterior screw to close the plug.
      Ask FixBot
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
19 other people completed this guide.
Tim Spellings
583 Reputation
1 Guide authored
Texas Tech, Team 3-2, Rauch SU 2015 Member of Texas Tech, Team 3-2, Rauch SU 2015
TTU-RAUCH-SU15S3G2
3 Members
12 Guides authored
7 Guide Comments
Passt - gute Anleitung
Martin Winter - Reply Share
A version for 3 prong (North American) would be great
James Harrison - Reply Share
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - Reply Share
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - Reply Share
Buy a plug that can be opened with a screw
Toon Konings - Reply Share
Past 24 Hours: 14
Past 7 Days: 121
Past 30 Days: 496
All Time: 56,413
