Electric Lava Lamp Lightbulb Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
109
All Time:
922
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your electric lava lamp goes out and will not turn back on, you may need to replace the lightbulb. This guide goes step by step through the process of replacing your electric lava lamp's lightbulb. This guide shouldn't take more than 5-10 minutes depending on how long it takes for the lava lamp to cool down after being plugged in.
    1. Electric Lava Lamp Lightbulb Replacement, Lightbulb: step 1, image 1 of 1
      • Unplug the electric lava lamp and wait for it to cool down.
      • Warning: If the lightbulb/lamp is still hot while trying to replace it, it could cause severe burns and injuries
      Ask FixBot
    2. Electric Lava Lamp Lightbulb Replacement: step 2, image 1 of 2 Electric Lava Lamp Lightbulb Replacement: step 2, image 2 of 2
      • Remove the pink covering of the lava lamp by simply lifting it, and do the same for the bottle section.
      Ask FixBot
    3. Electric Lava Lamp Lightbulb Replacement: step 3, image 1 of 1
      • Once everything has been removed the lightbulb will be visible.
      Ask FixBot
    4. Electric Lava Lamp Lightbulb Replacement: step 4, image 1 of 3 Electric Lava Lamp Lightbulb Replacement: step 4, image 2 of 3 Electric Lava Lamp Lightbulb Replacement: step 4, image 3 of 3
      • Place your fingers around the lightbulb and slowly twist in a leftward (counterclockwise) direction until it becomes loose.
      Ask FixBot
    5. Electric Lava Lamp Lightbulb Replacement: step 5, image 1 of 2 Electric Lava Lamp Lightbulb Replacement: step 5, image 2 of 2
      • Slowly take out the lightbulb and replace it with the new one.
      Ask FixBot
    6. Electric Lava Lamp Lightbulb Replacement: step 6, image 1 of 2 Electric Lava Lamp Lightbulb Replacement: step 6, image 2 of 2
      • You've successfully replaced the lightbulb!
      Ask FixBot
Finish Line
2 other people completed this guide.
Maria
166 Reputation
1 Guide authored
UC Davis, Team 3-4, Andersen Winter 2025 Member of UC Davis, Team 3-4, Andersen Winter 2025
UCD-ANDERSEN-W25S3G4
3 Members
12 Guides authored
1 Guide Comment
En wat als hij het met een nieuwe lamp nog niet doet?
Arlette Wienholds - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 109
All Time: 922
