Eightarc Fusion USB Cable Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
88
All Time:
1,494
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Use this guide if the USB cable is no longer working.
Warning: Use caution when placing the joystick face down on the table. The joystick can crack if placed down too hard. Be sure to gently turn the device over and place it face down. It can be helpful to balance the other side of the device to distribute the weight.
Tools
    1. Eightarc Fusion USB Cable Replacement, USB Cable: step 1, image 1 of 2 Eightarc Fusion USB Cable Replacement, USB Cable: step 1, image 2 of 2
      • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
      • Place the controller face down (buttons and joystick down).
      • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
      • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
      Ask FixBot
    2. Eightarc Fusion USB Cable Replacement: step 2, image 1 of 1
      • Open the door for the cord storage compartment on the right side of the device.
      • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
      Ask FixBot
    3. Eightarc Fusion USB Cable Replacement: step 3, image 1 of 1
      • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
      • Be sure to be gentle and not snap the plastic flap in half.
      Ask FixBot
    4. Eightarc Fusion USB Cable Replacement: step 4, image 1 of 1
      • Slide USB cable up from the plastic barrier casing.
      Ask FixBot
    5. Eightarc Fusion USB Cable Replacement: step 5, image 1 of 3 Eightarc Fusion USB Cable Replacement: step 5, image 2 of 3 Eightarc Fusion USB Cable Replacement: step 5, image 3 of 3
      • The USB cord is connected to the logic board by a plastic plug with five wires.
      • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
      • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
      • Remove USB cable from device.
      Ask FixBot
Dana
141 Reputation
1 Guide authored
Cal Poly, Team 17-35, Amido Winter 2015 Member of Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Members
60 Guides authored
1 Guide Comment
Where do I get the USB wire?
desmond.bouey1 - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 88
All Time: 1,494
