Eightarc Fusion Joystick Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
34
Past 30 Days:
98
All Time:
1,646
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide shows how to remove and disassemble the joystick from the controller. This will allow the user to clean under the joystick or replace it.
Warning: Use caution when placing the joystick face down on the table. The joystick can crack if placed down too hard. Be sure to gently turn the device over and place it face down. It can be helpful to balance the other side of the device to distribute the weight.
Tools
    1. Eightarc Fusion Joystick Replacement, Joystick: step 1, image 1 of 2 Eightarc Fusion Joystick Replacement, Joystick: step 1, image 2 of 2
      • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
      • Place the controller face down (buttons and joystick down).
      • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
      • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
      Ask FixBot
    2. Eightarc Fusion Joystick Replacement: step 2, image 1 of 1
      • Open the door for the cord storage compartment on the right side of the device.
      • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
      Ask FixBot
    3. Eightarc Fusion Joystick Replacement: step 3, image 1 of 2 Eightarc Fusion Joystick Replacement: step 3, image 2 of 2
      • Use the large plastic opening tool to softly pry the lip on the white 5 pin connector to relieve pressure while pulling the 5 pin connector.
      • Remove the white connector from the microswitch assembly.
      Ask FixBot
    4. Eightarc Fusion Joystick Replacement: step 4, image 1 of 2 Eightarc Fusion Joystick Replacement: step 4, image 2 of 2
      • Insert a #4 Flat Head screwdriver into the shaft of the joystick and grasp the ball topper with your other hand.
      • Turn the flat head screwdriver counter clockwise for a quarter turn while tightly holding the ball topper.
      • The ball topper should now be loose enough to unscrew by hand.
      • Set aside the shaft cover, dust cover, and ball topper.
      Ask FixBot
    5. Eightarc Fusion Joystick Replacement: step 5, image 1 of 2 Eightarc Fusion Joystick Replacement: step 5, image 2 of 2
      • Remove the four 8.35 mm screws from the mounting plate of the joystick using a Phillips Head #2 screwdriver.
      • Remove the joystick assembly from the controller.
      Ask FixBot
    6. Eightarc Fusion Joystick Replacement: step 6, image 1 of 3 Eightarc Fusion Joystick Replacement: step 6, image 2 of 3 Eightarc Fusion Joystick Replacement: step 6, image 3 of 3
      • Place joystick assembly on a hard, flat surface.
      • Gently press on the four black tabs on each side of the assembly.
      • With the tabs depressed, lift the clear restrictor plate from the assembly.
      Ask FixBot
    7. Eightarc Fusion Joystick Replacement: step 7, image 1 of 1
      • Remove the switch housing from the assembly by lifting straight up.
      • The joystick assembly is now ready to be replaced or cleaned.
      Ask FixBot
Austin
245 Reputation
2 Guides authored
Cal Poly, Team 17-35, Amido Winter 2015 Member of Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 98
All Time: 1,646
