Egg Slicer Wire Replacement
    1. Egg Slicer Wire Replacement, Wire: step 1, image 1 of 2 Egg Slicer Wire Replacement, Wire: step 1, image 2 of 2
      • Do not repeatedly bend clamps. This weakens the metal and makes it more susceptible to damage.
      • It is strongly recommended that you wear personal protective equipment when completing this repair. The wires may present a pinching or scratching hazard.
      • Using the flat nosed pliers, pry the clamp open.
      • Grip the clamp and bend to a 90 degree angle.
      • Repeat this step for every clamp.
      Ask FixBot
    2. Egg Slicer Wire Replacement: step 2, image 1 of 1
      • Unwind the old wire from the slicer.
      • Extend the wire and put to the side.
      • You should now be left with the skeleton of the egg slicer.
      Ask FixBot
    3. Egg Slicer Wire Replacement: step 3, image 1 of 2 Egg Slicer Wire Replacement: step 3, image 2 of 2
      • Take the old wire and extend it out as much as possible.
      • Straighten out any bends in the old wire for accuracy.
      • Place your old wire at the 0 mark of the measuring tape.
      • Take the measurement of your old wire and take note of its length.
      • It is recommended that you mark the length of your old wire on your measuring tape.
      • Use the length you recorded to cut a new wire and put it to the side.
      Ask FixBot
    4. Egg Slicer Wire Replacement: step 4, image 1 of 2 Egg Slicer Wire Replacement: step 4, image 2 of 2
      • Take the new wire, and anchor it by tying it in a loop around one of the clamp.
      • Pull the wire as tight as possible to the right side of clamp.
      Ask FixBot
    5. Egg Slicer Wire Replacement: step 5, image 1 of 3 Egg Slicer Wire Replacement: step 5, image 2 of 3 Egg Slicer Wire Replacement: step 5, image 3 of 3
      • Loop the wire tightly around the clamp.
      • Rotate the wire in a counterclockwise direction.
      • When you reach the clamp across from it, loop it around the clamp, and pull the wire to clamp to the right of it.
      • Repeat these steps until you reach the final clamp.
      Ask FixBot
    6. Egg Slicer Wire Replacement: step 6, image 1 of 3 Egg Slicer Wire Replacement: step 6, image 2 of 3 Egg Slicer Wire Replacement: step 6, image 3 of 3
      • Before anchoring the loop, make sure that you have pulled the wires to be as tight as possible.
      • Once at the final clamp repeat step 4.
      • Anchor the loop by looping the wire as tight as possible.
      Ask FixBot
    7. Egg Slicer Wire Replacement: step 7, image 1 of 1
      • With the flat nosed pliers, clamp down all the clamps.
      • Cut any excess wire so you have a sturdy fit for your new wire.
      Ask FixBot
Finish Line
Diego Jimenez 213
145 Reputation
1 Guide authored
UC Davis, Team 2-6, Andersen Winter 2025 Member of UC Davis, Team 2-6, Andersen Winter 2025
UCD-ANDERSEN-W25S2G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 49
Past 30 Days: 192
All Time: 1,753
