Edifier MP260 Battery Removal
Views: 4.6K
View statistics:
Past 24 Hours:
Past 7 Days:
39
Past 30 Days:
195
All Time:
4,550
Comments: 22
3 comments on steps, 19 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Disclaimer
Based on my experience, this speaker was originally designed to run with its built-in battery. Without it, the unit will still power ON via the USB port, but has the tendency to sometimes shut off at higher volumes or during bass heavy playback (especially movies).
Tools
      • Before starting the disassembly, make sure the speaker is powered off and disconnected from any charging source to prevent any potential electrical shock.
      • I've also did this on a completely deplected battery just to be extra sure.
      Ask FixBot
    1. Edifier MP260 Battery Removal, Pry Open the Speaker: step 2, image 1 of 3 Edifier MP260 Battery Removal, Pry Open the Speaker: step 2, image 2 of 3 Edifier MP260 Battery Removal, Pry Open the Speaker: step 2, image 3 of 3
      • At the bottom of the speaker, carefully insert a plastic opening tool into the seam between the front panel and the main body. Gently pry the front panel open, working your way from the bottom to the top.
      • Be cautious, as the top part of the speaker contains the battery cage, which houses delicate wires. Take care not to damage them while prying the front cover. Additionally, be mindful to avoid accidentally poking the speaker itself.
      Ask FixBot
    2. Edifier MP260 Battery Removal, Remove the Screws Holding the Battery: step 3, image 1 of 3 Edifier MP260 Battery Removal, Remove the Screws Holding the Battery: step 3, image 2 of 3 Edifier MP260 Battery Removal, Remove the Screws Holding the Battery: step 3, image 3 of 3
      • There are four screws securing the battery cage, which includes the battery, its wires, the left and right channel wires, and the main audio wire. Use a Phillips screwdriver (PH2 or larger) to remove them, and keep the screws safe for reassembly
      Ask FixBot
    3. Edifier MP260 Battery Removal, Disconnect the Battery and Speaker Wires: step 4, image 1 of 2 Edifier MP260 Battery Removal, Disconnect the Battery and Speaker Wires: step 4, image 2 of 2
      • Now, carefully disconnect the battery cable and the speaker wires from the motherboard. For each connector, gently lift the latch to disconnect it. You can use your fingers for this, but tweezers may help if you need more precision.
      • Refer to the second image, which has three marked circles: the bottom indicates the battery connector, while the middle and top circles correspond to the speaker wires.
      • Be gentle to avoid touching any delicate components, including capacitors and other electrical parts nearby, as they may hold residual power and pose a risk of electric shock.
      Ask FixBot
    4. Edifier MP260 Battery Removal, Remove the Old Battery: step 5, image 1 of 3 Edifier MP260 Battery Removal, Remove the Old Battery: step 5, image 2 of 3 Edifier MP260 Battery Removal, Remove the Old Battery: step 5, image 3 of 3
      • The wires pass through a hole in the battery cage, which is also glued to hold them in place. The easiest way to remove the battery wires from the hole is to just cut them. Cut them one by one to avoid shorting the battery.
      • To remove the battery from the cage, unscrew the two screws holding it in place. Since the wires are glued, use a hairdryer to soften the adhesive and gently pull the cable out.
      Ask FixBot
    5. Edifier MP260 Battery Removal, Reassemble the Speaker: step 6, image 1 of 3 Edifier MP260 Battery Removal, Reassemble the Speaker: step 6, image 2 of 3 Edifier MP260 Battery Removal, Reassemble the Speaker: step 6, image 3 of 3
      • To reassemble the speaker, reverse the disassembly steps.
      Ask FixBot
5 other people completed this guide.
chaeryeong
308 Reputation
1 Guide authored
19 Guide Comments
Thank you for this guide. The same speaker I have just went bust, luckily it's still under warranty. Definitely will come in useful for the next change.
Howie Chin - Reply Share
Thank you for this guide, the battery is dead and I have to change it.
It's disassembled (thanks to you) and now I have to find the right battery with the same amount of cables (4 apparently)
Bo DAYS - Reply Share
Hello, thanks for the guide. I followed it but had a problem with reassembly, here, would you happen to know how you reassembled it? Whenever I push the top part down, the front panel goes forward so I haven't been able to reassemble it like before
Gio - Reply Share
Hello Gio,
If you check well, on top of the device, you have 2 "brackets" letf and right sides (here) to attach the top part and in front, and 7 wholes (here) to attach the front part.
To reassemble the 2 pieces, your have to :
- present to white piece a bit upfront the wholes in order to slide its top part into the 2 brackets on top of the device.
- by doing so, you will attach the top parts together and in the same time, enter the "pins" into the 7 front wholes.
- You will have to apply a bit of strengh but it should work
A bit difficult to explain but I hope it's clear.
Bo
Hello Bo, could it be possible that my connectors to the brackets are broken? here, have tried everything but can't seem to get it to close
Gio - Reply Share
Past 24 Hours: 1
Past 7 Days: 39
Past 30 Days: 195
All Time: 4,550
