Edco KL14 Belt Guard Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Edco KL14  Belt Guard Replacement, Disengage the Spark Plug: step 1, image 1 of 2 Edco KL14  Belt Guard Replacement, Disengage the Spark Plug: step 1, image 2 of 2
      • Before you begin, ensure that the machine is powered down and cool to the touch.
      • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
      • Grab the plastic spark plug cap at the end of the spark plug wire.
      • Firmly pull to disconnect the spark plug cap from the spark plug.
      Ask FixBot
    2. Edco KL14  Belt Guard Replacement, Place Wheel Chocks: step 2, image 1 of 3 Edco KL14  Belt Guard Replacement, Place Wheel Chocks: step 2, image 2 of 3 Edco KL14  Belt Guard Replacement, Place Wheel Chocks: step 2, image 3 of 3
      • To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
      Ask FixBot
    1. Edco KL14  Belt Guard Replacement, Remove the Arbor Guard: step 3, image 1 of 2 Edco KL14  Belt Guard Replacement, Remove the Arbor Guard: step 3, image 2 of 2
      • Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
      • Remove the arbor guard.
      Ask FixBot
    2. Edco KL14  Belt Guard Replacement, Remove the Belt Guard: step 4, image 1 of 3 Edco KL14  Belt Guard Replacement, Remove the Belt Guard: step 4, image 2 of 3 Edco KL14  Belt Guard Replacement, Remove the Belt Guard: step 4, image 3 of 3
      • Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
      • Remove the belt guard.
      Ask FixBot
Craig Lloyd
43,606 Reputation
82 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 97
