Introduction
If your weight scale is showing the message LO on the display screen, this guide can help you to fix it. This step-by-step instruction teaches you how to replace the items on the device in order to make your device work again. You will need to prepare 4 AAA batteries in advance in order to complete this repair.
To open the battery compartment, use your finger to gentling push the tip to open the battery compartment.
Remove the old batteries from the device by pushing the battery toward the wire side and gentling taking it out.
Put the cover of the compartment back. You successfully replaced the batteries.
You should now see the weight displaying on the screen after the replacement.
