Introduction
This guide is a detailed process on how to remove the vibration motors on the EasySMX ESM-9110 gaming controller. The EasySMX ESM-9110 controller contains two vibration motors which operate during gameplay. The replacement of these vibration motors will most likely fix any issues being had.
Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
Use a Phillips #000 screwdriver to remove the four 20 mm screws from the controller's faceplate.
Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
