EasySMX ESM-9110 Turbo Button Replacement
  1. EasySMX ESM-9110 Turbo Button Replacement, Handle Covers: step 1, image 1 of 2 EasySMX ESM-9110 Turbo Button Replacement, Handle Covers: step 1, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Turbo Button Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Turbo Button Replacement: step 3, image 1 of 1
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: step 4, image 1 of 3 EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: step 4, image 2 of 3 EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: step 4, image 3 of 3
    • Use a Philips #000 screwdriver to remove the six 20 mm screws from the controller's faceplate.
  5. EasySMX ESM-9110 Turbo Button Replacement: step 5, image 1 of 3 EasySMX ESM-9110 Turbo Button Replacement: step 5, image 2 of 3 EasySMX ESM-9110 Turbo Button Replacement: step 5, image 3 of 3
    • Using a soldering iron, solder the turbo button.
Melanie Rodriguez
406 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 274
