EasySMX ESM-9110 Joystick Cover Replacement
  1. EasySMX ESM-9110 Joystick Cover Replacement, Backplate: step 1, image 1 of 3 EasySMX ESM-9110 Joystick Cover Replacement, Backplate: step 1, image 2 of 3 EasySMX ESM-9110 Joystick Cover Replacement, Backplate: step 1, image 3 of 3
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
  2. EasySMX ESM-9110 Joystick Cover Replacement: step 2, image 1 of 1
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
  3. EasySMX ESM-9110 Joystick Cover Replacement: step 3, image 1 of 3 EasySMX ESM-9110 Joystick Cover Replacement: step 3, image 2 of 3 EasySMX ESM-9110 Joystick Cover Replacement: step 3, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
  4. EasySMX ESM-9110 Joystick Cover Replacement, Joystick Cover: step 4, image 1 of 2 EasySMX ESM-9110 Joystick Cover Replacement, Joystick Cover: step 4, image 2 of 2
    • Remove the four 10 mm Phillips screws from the motherboard.
    • Be careful removing the motherboard as the trigger buttons are attached loosely and can be inconvenient.
  5. EasySMX ESM-9110 Joystick Cover Replacement: step 5, image 1 of 1
    • Remove the faulty joystick.
    • Clean the joystick if it is dirty and causing stick drift.
Caleb French
88 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 50
All Time: 734
