Easier way to open
  1. Easier way to open, Open the balance: step 1, image 1 of 1
    • Since it is not important in the balance to get the adhesive surfaces take a beveled spatula. It's much easier and faster.
  2. Easier way to open: step 2, image 1 of 2 Easier way to open: step 2, image 2 of 2
    • Contrary to the other instructions, the board is located directly on the plastic housing. Through the 3 holes water gets into the balance and through the adhesion it spreads over the complete underside of the board
    • The Libra continues to change. Only this time too much water had penetrated which had spread under the board.
    • Clean the underside of the board with acetone. Alternatively, isopropanol.
    • After the board was dry, the scales spoke to me again. And so that water does not penetrate again, I taped the holes with silicone
    • Finally, glue the round cap to the glass plate with a little silicone glue. Because even if the board has a silicone protective coating, it would not be good if Wassser came from above on the SMD components.
Repeat the steps in order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Marina
115 Reputation
1 Guide authored
3 Guide Comments
this does not tell you how to open it, only to use a spatula. this is not a guide, it is a waste of time.
David Hopkins - Reply
I support the opinion expressed above. waste of time...
A K - Reply
The 4 load cells are glued to the glass plate.
This means you only have to cut through the adhesive pads from the side
Marina -
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 44
All Time: 3,159
