Mi 8 Explorer Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
40
Past 30 Days:
124
All Time:
1,619
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
My old Xiaomi Mi 8 Explorer needed a new battery, and while trying to find a guide on here, I noticed that the nearest one I could find was for the Pro version, So I decided to make a guide to change said battery (about half way through the replacement, don't judge!)
Parts
Tools
    1. Mi 8 Explorer Battery Replacement, Battery: step 1, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • As per usual, heat the glue to soften it, and use picks to cut.
      • I found that it was pretty easy to get in there by using a suction cup with a small amount of pressure along with a Halberd spudger to get it started.
      Ask FixBot
    2. Mi 8 Explorer Battery Replacement: step 2, image 1 of 3 Mi 8 Explorer Battery Replacement: step 2, image 2 of 3 Mi 8 Explorer Battery Replacement: step 2, image 3 of 3
      • Next step is to remove the screws that keep the plastic back plate on. You'll find:
      • Pentalobe P2 screw (x9)
      • NFC Module
      • Use a spudger to remove the plastic plate, being careful with the NFC module (form what I saw, it doesn't detach form the plate, and even if it does, it's just easier to keep it together
      Ask FixBot
    3. Mi 8 Explorer Battery Replacement: step 3, image 1 of 3 Mi 8 Explorer Battery Replacement: step 3, image 2 of 3 Mi 8 Explorer Battery Replacement: step 3, image 3 of 3
      • Unclip the battery connector and remove the sticker over the battery, to see the battery in all its glory!
      Ask FixBot
    4. Mi 8 Explorer Battery Replacement: step 4, image 1 of 2 Mi 8 Explorer Battery Replacement: step 4, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • Remove the battery, unlike the Original Mi 8 Pro, I didn't find any glue tabs to remove the battery, so I used a mix of my Halberd Spudger, and a plastic card to remove the battery.
      • Insert the replacement battery, and test the phone.
      Ask FixBot
Once ready, follow steps backwards as normal!
2 other people completed this guide.
J.McGaley
192 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 124
All Time: 1,619
