EK3211 Kitchen Scale Disassembly
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
26
Past 30 Days:
130
All Time:
1,499
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. EK3211 Kitchen Scale Disassembly, Remove label to access screws: step 1, image 1 of 1
      • Peel back the "ELECTRONIC KITCHEN SCALE" label to reveal two screws underneath.
      Ask FixBot
    2. EK3211 Kitchen Scale Disassembly: step 2, image 1 of 1
      • Use a #2 Phillips screwdriver to remove the two screws.
      • These screws are very tight and prone to strip.
      Ask FixBot
    3. EK3211 Kitchen Scale Disassembly: step 3, image 1 of 1
      • Remove the four screws holding the top veneer panel to the base.
      Ask FixBot
    4. EK3211 Kitchen Scale Disassembly: step 4, image 1 of 1
      • Remove the top veneer panel. It should come off without any force.
      • There are two small plastic clips on the edge below the screen, which must be inserted correctly during reassembly.
      Ask FixBot
    5. EK3211 Kitchen Scale Disassembly: step 5, image 1 of 1
      • Remove the screw holding the PCB and screen in place using a #1 Phillips screwdriver.
      Ask FixBot
    6. EK3211 Kitchen Scale Disassembly: step 6, image 1 of 1
      • Remove the PCB and screen assembly.
      • The buttons should also lift up with the rest of the PCB/screen assembly.
      Ask FixBot
    7. EK3211 Kitchen Scale Disassembly: step 7, image 1 of 1
      • Use a #1 Phillips screwdriver to remove the four screws holding the load cell mount to the base.
      Ask FixBot
    8. EK3211 Kitchen Scale Disassembly: step 8, image 1 of 1
      • Remove the two screws holding the load cell to the bracket using a #2 Phillips screwdriver.
      Ask FixBot
    9. EK3211 Kitchen Scale Disassembly: step 9, image 1 of 1
      • Separate the bracket from the load cell.
      • Be careful not to lose the spacer plate.
      Ask FixBot
2 other people completed this guide.
Steven Bell
583 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 130
All Time: 1,499
