Up to 20% off select tools
EBK340 Powerhead Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
73
All Time:
530
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
It is very annoying to carry around the powerhead when it does not click together. Usually this results from wear on the plastic neck joint, which can be replaced.
    1. EBK340  Powerhead  Replacement, Remove Outer Cover: step 1, image 1 of 1
      • Position the device so brushes are upwards and visible
      • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
      • Turn over the device.
      • Pull the cover off gently.
      Ask FixBot
    2. EBK340  Powerhead  Replacement, Remove Inner Cover: step 2, image 1 of 1
      • Unscrew the 2 screws indicated, one visible, the other within a deep hole
      • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
      Ask FixBot
    3. EBK340  Powerhead  Replacement, Replace Neck Joint: step 3, image 1 of 2 EBK340  Powerhead  Replacement, Replace Neck Joint: step 3, image 2 of 2
      • Gently lift the two LED lights upwards and away for the moment.
      • Gently lift out the defective neck joint.
      • Slide in the replacement joint.
      • Replace the lights into the molded corners that hold their board.
      Ask FixBot
Author
with
FolsomMaids Office
167 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 73
All Time: 530
