Dyson V6 Motorhead Brush Bar Replacement
  1. Dyson V6 Motorhead Brush Bar Replacement, Brush Bar: step 1, image 1 of 1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Brush Bar Replacement: step 2, image 1 of 1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Brush Bar Replacement: step 3, image 1 of 3 Dyson V6 Motorhead Brush Bar Replacement: step 3, image 2 of 3 Dyson V6 Motorhead Brush Bar Replacement: step 3, image 3 of 3
    • Pull the brush bar out of the housing.
3 other people completed this guide.
Addie Hedge
710 Reputation
5 Guides authored
Cal Poly, Team 22-6, Maness Winter 2017 Member of Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Members
5 Guides authored
4 Comments
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - Reply
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - Reply
I have the same problem and I never signed up for the warranty.
Donna Sweeney - Reply
My motorhead works intermittely. I took it apart and cleaned everything to no avail. The guy at Starks vacuum in Sherwood OR said it was plugged and he would take it apart and clean it for $100. Hmmmm, what can he clean that I can’t?
Roger and Karen Risch - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 53
All Time: 21,819
