Dyson V12 Filter Cleaning
View statistics:
Past 24 Hours:
14
Past 7 Days:
123
Past 30 Days:
415
All Time:
945
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 day
Difficulty: Easy
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to remove, wash, dry, and reinstall the filter in a Dyson V12 vacuum. A dirty filter can restrict airflow and reduce suction. The video demonstrates an older tissue-and-brush method; the written steps below follow Dyson's current V12 washing guidance. Wash the filter monthly, or more often after vacuuming fine dust or using Boost mode frequently. The filter must be completely dry before reinstallation.
Parts
  • Dyson V12 HEPA Post Filter
    5
    Optional
    Optional; replace the filter only if it is damaged, worn, or cleaning no longer restores performance.
    View
      • Turn off the Dyson V12 and disconnect it from the charger.
      • Turn the filter counterclockwise and gently pull it away from the vacuum.
      • Keep water away from the vacuum body, motor area, battery, and charging contacts.
      • Do not run or charge the vacuum while the filter is removed or wet.
      Ask FixBot
      • Gently tap the filter over a trash bin to remove loose dust and debris before washing it.
      • Inspect the filter media, housing, and seal for tears, cracks, or deformation.
      • Do not use tissue or a brush to scrub the pleated filter media.
      Ask FixBot
      • Hold the filter under warm running tap water with the foam element facing down.
      • Run warm water over the pleated paper element until the water runs clear.
      • Do not use detergent, hot water, a dishwasher, or a washing machine.
      • Do not scrub the pleated paper element with a brush.
      Ask FixBot
      • Keep the foam element facing down so dirty water cannot contaminate the pleated paper.
      • Run warm water over the inside and outside of the foam element, and gently squeeze the foam to expel dirt.
      • Wash the outside of the filter, fill it with warm water, cover the openings with your hands, and shake it gently.
      • Repeat the wash until the water runs clear.
      • Gently shake out excess water and leave the filter to drain with the foam element facing up.
      Ask FixBot
      • Leave the filter in a dry area with good airflow for at least 24 hours.
      • The filter must be completely dry before reinstallation.
      • Do not use a tumble dryer, oven, microwave, heater, or open flame to speed drying.
      • If the filter still feels damp after 24 hours, let it dry longer.
      Ask FixBot
      • Insert the completely dry filter into the vacuum.
      • Turn the filter clockwise until it clicks into place.
      • Run the vacuum briefly and check that airflow and suction have improved.
      Ask FixBot
      • Wash the filter once a month to help maintain suction.
      • Wash it more often after vacuuming fine dust or using Boost mode frequently.
      • Replace the filter if it is damaged, worn, or cleaning no longer restores performance.
      • Use a replacement that is compatible with Dyson V12 vacuums.
      Ask FixBot
After the completely dry filter is locked in place, run the vacuum briefly and check that airflow has improved. If the problem continues, ask the Dyson V12 Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 123
Past 30 Days: 415
All Time: 945
