Introduction
This guide details the process of replacing the eye pipes inside a Dye DAM(Dye Assault Matrix) Paintball marker. Eye pipes are a moving part inside this beautiful item and enable the player to switch between magazine fed mode and hopper fed mode in less than a second. It also stabilizes the paint balls until shot and allows for the detection of rounds when loaded into the chamber. All this functionality means that its a pretty standard part to clean when doing daily maintenance and sometimes may break. So its crucial that every owner know how to clean and replace it properly.
Using a 3/32" allen key loosen the 2.5 mm screw from the buttstock.
Remove the buttstock from the marker.
Now that your gun is taken apart and your eye pipes cleaned or replaced. You can follow these instructions in reverse to put your marker back together
