iPad Wi-Fi Home Button Switch Replacement
Views: 28K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
110
All Time:
28,161
Comments: 13
12 comments on steps, 1 guide comment.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 21
21 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a non-functioning home button switch.
Parts
Tools
    1. iPad Wi-Fi Home Button Switch Replacement, Display Assembly: step 1, image 1 of 3 iPad Wi-Fi Home Button Switch Replacement, Display Assembly: step 1, image 2 of 3 iPad Wi-Fi Home Button Switch Replacement, Display Assembly: step 1, image 3 of 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Ask FixBot
    2. iPad Wi-Fi Home Button Switch Replacement: step 2, image 1 of 2 iPad Wi-Fi Home Button Switch Replacement: step 2, image 2 of 2
      • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
      • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
      • If you do happen to break some clips, you can buy replacements here.
      Ask FixBot
    3. iPad Wi-Fi Home Button Switch Replacement: step 3, image 1 of 2 iPad Wi-Fi Home Button Switch Replacement: step 3, image 2 of 2
      • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
      • Rotate the spudger away from you to release the tabs along the top edge of the display.
      • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
      Ask FixBot
    4. iPad Wi-Fi Home Button Switch Replacement: step 4, image 1 of 2 iPad Wi-Fi Home Button Switch Replacement: step 4, image 2 of 2
      • With one spudger, work your way along the right edge of the iPad.
      • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
      • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
      • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
      Ask FixBot
    5. iPad Wi-Fi Home Button Switch Replacement: step 5, image 1 of 1
      • Lift the display assembly away from the rear panel assembly by its bottom edge.
      • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
      Ask FixBot
    6. iPad Wi-Fi Home Button Switch Replacement: step 6, image 1 of 1
      • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
      • Digitizer
      • Ambient Light Sensor
      • Display Data Cable
      Ask FixBot
    7. iPad Wi-Fi Home Button Switch Replacement: step 7, image 1 of 3 iPad Wi-Fi Home Button Switch Replacement: step 7, image 2 of 3 iPad Wi-Fi Home Button Switch Replacement: step 7, image 3 of 3
      • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
      • Be sure you are flipping up the retaining flap, not the socket itself.
      • Pull the digitizer ribbon cables straight out of their sockets.
      Ask FixBot
    8. iPad Wi-Fi Home Button Switch Replacement: step 8, image 1 of 1
      • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
      Ask FixBot
    9. iPad Wi-Fi Home Button Switch Replacement: step 9, image 1 of 2 iPad Wi-Fi Home Button Switch Replacement: step 9, image 2 of 2
      • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
      • Pull the cable connector away from its socket.
      • Pull the connector parallel to the face of the logic board.
      Ask FixBot
    10. iPad Wi-Fi Home Button Switch Replacement: step 10, image 1 of 1
      • Remove the display assembly from the rear panel assembly.
      Ask FixBot
    1. iPad Wi-Fi Home Button Switch Replacement, Home Button Switch: step 11, image 1 of 1
      • Remove the two T5 Torx screws securing the home button switch board to the display frame.
      Ask FixBot
    2. iPad Wi-Fi Home Button Switch Replacement: step 12, image 1 of 1
      • Remove the home button switch board from the display frame.
      Ask FixBot
10 other people completed this guide.
1 Guide Comment
If you prefer to watch a video of disassembly/reassembly for the home button diagnostics, I have successfully completed the whole process ;) You can see it here:
Apple iPad 1st Gen Home Button Malfunction - disassembly & repair (https://www.youtube.com/watch?v=lYwuIyFI...)
Even though I had a replacement home button board ready, it wasn't needed. Sometimes you just need to clean up contact pads and/or make sure that spring-loaded pins are not stuck. This unfortunately still requires screen removal, which means that some of the screen clips are going to break, that's just how it is :(
Just Make It - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 110
All Time: 28,161
