DualShock 4 Left Analog Stick Replacement
  1. DualShock 4 Left Analog Stick Replacement, Controller: step 1, image 1 of 1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
  2. DualShock 4 Left Analog Stick Replacement: step 2, image 1 of 3 DualShock 4 Left Analog Stick Replacement: step 2, image 2 of 3 DualShock 4 Left Analog Stick Replacement: step 2, image 3 of 3
    • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on tool to pry open the casing.
    • Repeat these steps for the right handle.
  3. DualShock 4 Left Analog Stick Replacement: step 3, image 1 of 3 DualShock 4 Left Analog Stick Replacement: step 3, image 2 of 3 DualShock 4 Left Analog Stick Replacement: step 3, image 3 of 3
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
  4. DualShock 4 Left Analog Stick Replacement, Disconnect the battery: step 4, image 1 of 2 DualShock 4 Left Analog Stick Replacement, Disconnect the battery: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  5. DualShock 4 Left Analog Stick Replacement, Remove the battery: step 5, image 1 of 1
    • Remove the battery.
  6. DualShock 4 Left Analog Stick Replacement, Disassembling DualShock 4 Motherboard Assembly: step 6, image 1 of 1
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
  7. DualShock 4 Left Analog Stick Replacement: step 7, image 1 of 2 DualShock 4 Left Analog Stick Replacement: step 7, image 2 of 2
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
  8. DualShock 4 Left Analog Stick Replacement: step 8, image 1 of 2 DualShock 4 Left Analog Stick Replacement: step 8, image 2 of 2
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  9. DualShock 4 Left Analog Stick Replacement, Disassembly Complete: step 9, image 1 of 3 DualShock 4 Left Analog Stick Replacement, Disassembly Complete: step 9, image 2 of 3 DualShock 4 Left Analog Stick Replacement, Disassembly Complete: step 9, image 3 of 3
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
  10. DualShock 4 Left Analog Stick Replacement, Left Analog Stick: step 10, image 1 of 3 DualShock 4 Left Analog Stick Replacement, Left Analog Stick: step 10, image 2 of 3 DualShock 4 Left Analog Stick Replacement, Left Analog Stick: step 10, image 3 of 3
    • Use a "Helping Hands" or similar tool to hold the circuit board steady for the solder work.
    • These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right.
    • Use a desoldering wick and flux to melt and remove the solder
  11. DualShock 4 Left Analog Stick Replacement: step 11, image 1 of 3 DualShock 4 Left Analog Stick Replacement: step 11, image 2 of 3 DualShock 4 Left Analog Stick Replacement: step 11, image 3 of 3
    • Once all the contacts are desoldered, the old joystick can be removed. This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
    • Ensure that the contacts of the replacement joystick are identical to the original.
    • Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes. The molten looking substance on the circuit board is the flux used for the desoldering.
  12. DualShock 4 Left Analog Stick Replacement: step 12, image 1 of 3 DualShock 4 Left Analog Stick Replacement: step 12, image 2 of 3 DualShock 4 Left Analog Stick Replacement: step 12, image 3 of 3
    • Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
    • Solder all the contacts to the board.
    • Here is the board after the repair. All that is left is to clean off the old flux with some isopropyl alcohol.
oldturkey03
786,706 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
582 Guides authored
Past 24 Hours: 92
Past 7 Days: 609
Past 30 Days: 1,991
All Time: 343,986
