Main Click Buttons
Views: 26K
View statistics:
Past 24 Hours:
6
Past 7 Days:
46
Past 30 Days:
224
All Time:
26,234
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 - 15 minutes
Difficulty: Easy
Main Click Buttons
Introduction
Go to step 1 ↓
Use this guide to remove and replace the click buttons
Tools
    1. Main Click Buttons, Click Buttons: step 1, image 1 of 2 Main Click Buttons, Click Buttons: step 1, image 2 of 2
      • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
      Ask FixBot
    2. Main Click Buttons: step 2, image 1 of 2 Main Click Buttons: step 2, image 2 of 2
      • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
      Ask FixBot
    3. Main Click Buttons: step 3, image 1 of 2 Main Click Buttons: step 3, image 2 of 2
      • Use a blue spudger to open the bottom battery port.
      Ask FixBot
    4. Main Click Buttons: step 4, image 1 of 2 Main Click Buttons: step 4, image 2 of 2
      • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
      Ask FixBot
    5. Main Click Buttons: step 5, image 1 of 3 Main Click Buttons: step 5, image 2 of 3 Main Click Buttons: step 5, image 3 of 3
      • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
      Ask FixBot
    6. Main Click Buttons: step 6, image 1 of 1
      • use side cutters to carefully diassasemble remaining plastic part of switch careful not to damage motherboard
      Ask FixBot
    7. Main Click Buttons: step 7, image 1 of 1
      • heat metal parts of switch with soldering iron until solder fully melting adding solder as needed to melt then pull through the top of the motherboard where the switch was with pliers.
      Ask FixBot
    8. Main Click Buttons: step 8, image 1 of 1
      • putting soldering iron on one side of the motherboard use a solder sucker on the opposite side to pull solder out of the holes
      Ask FixBot
    9. Main Click Buttons: step 9, image 1 of 1
      • place new switch into the set of 3 holes careful to retain original orientation.
      Ask FixBot
    10. Main Click Buttons: step 10, image 1 of 1
      • add solder to the new switch. (sorry for a lack of good photos, I didnt realize how easy it was to edit Ifixit guides and found the original lacking.)
      Ask FixBot
18 other people completed this guide.
6 Guide Comments
how are you supposed to put the feet back?
Owen Yuen - Reply Share
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - Reply Share
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - Reply Share
Are the side buttons the same?
S I - Reply Share
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Reply Share
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 224
All Time: 26,234
