Introduction
This guide will show the reader how to remove and replace the rumble motors for a Dualshock 4 controller.
Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
I spent an hour trying to push, pull, pry and hammer the motors out with no luck. They're really stuck in there. I finally solved it by wedging the iFixit jimmy tool into the top where you can see the adhesive residue, then sliding across to break the seal. After that they popped out easy.
13 other people completed this guide.
