Video Overview
This teardown is not a repair guide. To repair your Powerbeats Pro, use our service manual.
    Final Thoughts
    • The battery is a fairly common button-cell, and is only lightly soldered in place, meaning battery swaps are technically possible with the right tools.
    • The earbuds’ opening procedure is not totally destructive per se, but it will likely lead to at least some cosmetic damage.
    • The earbuds’ internal circuitry is all connected with fragile ribbon cables that do not detach, so a full disassembly can only be accomplished destructively.
    • The charging case is a nightmarish bucket of glue, making potential battery replacements unnecessarily difficult and destructive.
    Repairability Score
    Repairability 1 out of 10
    (10 is easiest to repair)
Taylor Dixon
72,640 Reputation
94 Guides authored
8 Guide Comments
Review missed the debris screens in the ear tubes which often get damaged. How to replace possibly.
chronus - Reply Share
I can’t connect them when they are in the case are connect if I take them out of the case they disconnected. and it says they need to be on and on range help please
Eduardo Gaspar - Reply Share
So far it is just the case for mine that seems broken - It won’t charge the buds properly. I really don’t mind cosmetic damage if I can replace the case’s battery (assuming that is the culprit). Where might I get a replacement battery? Also, if I used enough care, could I not just cut into the case closer to the battery to get at it from underneath?
Tom Hernandez - Reply Share
I pushed my mesh in on one of my pods. Is there any fix to just bring it back?
AuxCord Broke - Reply Share
My volume button is stuck. It will turn up and change songs. However I can not turn down the volume at all. Can I fix it somehow?
Lisa Nikodym - Reply Share
Past 24 Hours: 11
Past 7 Days: 53
Past 30 Days: 221
All Time: 51,518
