DualShock 4 CUH-ZCT2 Buttons Replacement
Views: 45K
View statistics:
Past 24 Hours:
20
Past 7 Days:
137
Past 30 Days:
662
All Time:
44,859
Comments: 11
9 comments on steps, 2 guide comments.
Go to guide comments
Completed: 55
55 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Parts
Tools
    1. DualShock 4 CUH-ZCT2 Buttons Replacement, Outer Shell: step 1, image 1 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement, Outer Shell: step 1, image 2 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement, Outer Shell: step 1, image 3 of 3
      • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
      • Pry the two halves of the shell apart using a plastic opening tool.
      • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
      Ask FixBot
    2. DualShock 4 CUH-ZCT2 Buttons Replacement: step 2, image 1 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement: step 2, image 2 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
      Ask FixBot
    1. DualShock 4 CUH-ZCT2 Buttons Replacement, Battery: step 3, image 1 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement, Battery: step 3, image 2 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement, Battery: step 3, image 3 of 3
      • Unplug the black and red wires from the power port located on the motherboard.
      • Remove the old battery from the controller.
      Ask FixBot
    2. DualShock 4 CUH-ZCT2 Buttons Replacement: step 4, image 1 of 2 DualShock 4 CUH-ZCT2 Buttons Replacement: step 4, image 2 of 2
      • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
      Ask FixBot
    3. DualShock 4 CUH-ZCT2 Buttons Replacement: step 5, image 1 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement: step 5, image 2 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement: step 5, image 3 of 3
      • Unhook the battery case from the motherboard, and pull it off.
      Ask FixBot
    1. DualShock 4 CUH-ZCT2 Buttons Replacement, Buttons: step 6, image 1 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement, Buttons: step 6, image 2 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement, Buttons: step 6, image 3 of 3
      • Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
      Ask FixBot
    2. DualShock 4 CUH-ZCT2 Buttons Replacement: step 7, image 1 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement: step 7, image 2 of 3 DualShock 4 CUH-ZCT2 Buttons Replacement: step 7, image 3 of 3
      • Remove the rubber pads that secure the buttons in place for the arrow buttons, shape buttons, and Playstation Home button.
      • Do not turn the front shell cover upside down after completing this step, because some of the buttons may fall out.
      Ask FixBot
    3. DualShock 4 CUH-ZCT2 Buttons Replacement: step 8, image 1 of 2 DualShock 4 CUH-ZCT2 Buttons Replacement: step 8, image 2 of 2
      Buy
      • Remove the old buttons, and replace them with new ones using a pair of tweezers.
      Ask FixBot
55 other people completed this guide.
Michelle Joseph
2,151 Reputation
3 Guides authored
USF Tampa, Team S1-G5, Leahy Fall 2017 Member of USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
3 Members
60 Guides authored
2 Guide Comments
Where can I buy cuh zct2e spares from please
Paramdeep Dhaliwal - Reply Share
Can’t see an updated guide, and this one worked perfectly fine. Used to replace the buttons on a knock-off DualShock 4 from AliExpress. Construction was largely the same, only devoid of a screw anchoring the battery cradle. Would argue this was an extremely easy repair!
Casey - Reply Share
Past 24 Hours: 20
Past 7 Days: 137
Past 30 Days: 662
All Time: 44,859
