Introduction
The Charging Assembly tends to lose energy and stops working from overheating. This will cause the LED or USB charging port to no longer work. Use this guide to replace the Charging Assembly.
Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver
Place the removed screws to the side.
If you have followed all the steps correctly, your LED Light should light up once you reassemble and plug your device to a USB cord. To reassemble your device, follow these instructions in reverse order.
3 other people completed this guide.
