Shop the Holiday Gift Guide
DualShock 4 Buttons Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
23
All Time:
233
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
The official guide has been updated and can be found here.
Use this guide to replace or fix any buttons on the Dualshock 4 controller.
Parts
Tools
    1. DualShock 4 Buttons Replacement, Buttons: step 1, image 1 of 1
      • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
      • Do not forcefully loosen the screws, as it will amount to permanent damage of the threads, making removal impossible.
      Ask FixBot
    2. DualShock 4 Buttons Replacement: step 2, image 1 of 3 DualShock 4 Buttons Replacement: step 2, image 2 of 3 DualShock 4 Buttons Replacement: step 2, image 3 of 3
      • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
      • The clips help hold the seams together. If you break these clips, the controller will still work.
      • Beginning with the left handle:
      • Pinch the left handle of the controller to introduce an opening.
      • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
      • Pull down on the plier to crack open the casing.
      • Repeat these steps for the right handle.
      Ask FixBot
    3. DualShock 4 Buttons Replacement: step 3, image 1 of 3 DualShock 4 Buttons Replacement: step 3, image 2 of 3 DualShock 4 Buttons Replacement: step 3, image 3 of 3
      • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
      • Share button
      • Options button
      • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
      • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
      • 2 Trigger Springs
      • 1 Grey Reset Button Extension
      Ask FixBot
    4. DualShock 4 Buttons Replacement, Disconnect the battery: step 4, image 1 of 2 DualShock 4 Buttons Replacement, Disconnect the battery: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
      • Only pull on the head of the connector—don't pull on the cable itself.
      Ask FixBot
    5. DualShock 4 Buttons Replacement, Remove the battery: step 5, image 1 of 1
      • Remove the battery.
      Ask FixBot
    6. DualShock 4 Buttons Replacement: step 6, image 1 of 1
      • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
      • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
      Ask FixBot
    7. DualShock 4 Buttons Replacement: step 7, image 1 of 2 DualShock 4 Buttons Replacement: step 7, image 2 of 2
      • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
      Ask FixBot
    8. DualShock 4 Buttons Replacement: step 8, image 1 of 2 DualShock 4 Buttons Replacement: step 8, image 2 of 2
      • Carefully dislodge the motherboard assembly from the front cover.
      • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
      • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
      Ask FixBot
    9. DualShock 4 Buttons Replacement, Disassembly Complete: step 9, image 1 of 3 DualShock 4 Buttons Replacement, Disassembly Complete: step 9, image 2 of 3 DualShock 4 Buttons Replacement, Disassembly Complete: step 9, image 3 of 3
      • Successful disassembly of the controller will result in the following three parts, respectively:
      • Motherboard Assembly
      • Front Cover
      • Rear Cover
      Ask FixBot
    10. DualShock 4 Buttons Replacement: step 10, image 1 of 3 DualShock 4 Buttons Replacement: step 10, image 2 of 3 DualShock 4 Buttons Replacement: step 10, image 3 of 3
      • Remove the rubber covering concealing the buttons with your fingers.
      • Use the metal tweezers to then remove the button from its slot.
      Ask FixBot
    11. DualShock 4 Buttons Replacement: step 11, image 1 of 3 DualShock 4 Buttons Replacement: step 11, image 2 of 3 DualShock 4 Buttons Replacement: step 11, image 3 of 3
      • To remove the arrow key buttons, use the same process you used for the control buttons by removing the rubber cover and pulling the button out with metal tweezers.
      Ask FixBot
    12. DualShock 4 Buttons Replacement: step 12, image 1 of 2 DualShock 4 Buttons Replacement: step 12, image 2 of 2
      • For the share and options buttons, use the metal tweezers to grasp and remove them.
      Ask FixBot
    13. DualShock 4 Buttons Replacement: step 13, image 1 of 2 DualShock 4 Buttons Replacement: step 13, image 2 of 2
      • In order to remove the PS button on the controller, you must first remove the rubber cover with your fingers.
      • Then using the metal tweezers, remove the PS button.
      Ask FixBot
Author
with
Mark
8,121 Reputation
4 Guides authored
Cal Poly, Team 6-21, Maness Winter 2014 Member of Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 23
All Time: 233
