DualShock 4 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. DualShock 4 Battery Replacement, Battery: step 1, image 1 of 1
      • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
      • Do not forcefully loosen the screws, as it will amount to permanent damage of the threads, making removal impossible.
      Ask FixBot
    2. DualShock 4 Battery Replacement: step 2, image 1 of 3 DualShock 4 Battery Replacement: step 2, image 2 of 3 DualShock 4 Battery Replacement: step 2, image 3 of 3
      • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
      • The clips help hold the seams together. If you break these clips, the controller will still work.
      • Beginning with the left handle:
      • Pinch the left handle of the controller to introduce an opening.
      • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
      • Pull down on the plier to crack open the casing.
      • Repeat these steps for the right handle.
      Ask FixBot
    3. DualShock 4 Battery Replacement: step 3, image 1 of 3 DualShock 4 Battery Replacement: step 3, image 2 of 3 DualShock 4 Battery Replacement: step 3, image 3 of 3
      • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
      • Share button
      • Options button
      • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
      • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
      • 2 Trigger Springs
      • 1 Grey Reset Button Extension
      Ask FixBot
    4. DualShock 4 Battery Replacement: step 4, image 1 of 3 DualShock 4 Battery Replacement: step 4, image 2 of 3 DualShock 4 Battery Replacement: step 4, image 3 of 3
      • Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
      • Note the orientation of the cable and make sure it faces the right way when you reconnect it.
      • After the two halves are separated, place the top of the controller off to the side.
      Ask FixBot
    5. DualShock 4 Battery Replacement: step 5, image 1 of 3 DualShock 4 Battery Replacement: step 5, image 2 of 3 DualShock 4 Battery Replacement: step 5, image 3 of 3
      • Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug.
      • After removal of the plug from the motherboard, the battery can be lifted off of the controller.
      • Hasty removal of the battery plug could warp the plastic grips of the plug.
      Ask FixBot
Mark
8,106 Reputation
6 Guides authored
Cal Poly, Team 6-21, Maness Winter 2014 Member of Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 Members
86 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 315
