DualShock 3 thumbstick replacement
Views: 2.1K
View statistics:
Past 24 Hours:
19
Past 7 Days:
137
Past 30 Days:
475
All Time:
2,073
Comments: 36
36 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
    1. DualShock 3 thumbstick replacement, Rear Cover: step 1, image 1 of 1
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
      Ask FixBot
    2. DualShock 3 thumbstick replacement: step 2, image 1 of 1
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
      Ask FixBot
    3. DualShock 3 thumbstick replacement: step 3, image 1 of 2 DualShock 3 thumbstick replacement: step 3, image 2 of 2
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
      Ask FixBot
    1. DualShock 3 thumbstick replacement, Battery: step 4, image 1 of 1
      • Lift the battery off the motherboard for enough clearance to access the battery connector.
      Ask FixBot
    2. DualShock 3 thumbstick replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully pull the battery connector away from its socket on the motherboard.
      • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
      Ask FixBot
    1. DualShock 3 thumbstick replacement, Motherboard Assembly: step 6, image 1 of 1
      • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
      Ask FixBot
    2. DualShock 3 thumbstick replacement: step 7, image 1 of 3 DualShock 3 thumbstick replacement: step 7, image 2 of 3 DualShock 3 thumbstick replacement: step 7, image 3 of 3
      • Slide the trigger button retainers slightly away from the front cover.
      • Remove the #1 button on both sides.
      Ask FixBot
    3. DualShock 3 thumbstick replacement: step 8, image 1 of 2 DualShock 3 thumbstick replacement: step 8, image 2 of 2
      • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
      Ask FixBot
    4. DualShock 3 thumbstick replacement: step 9, image 1 of 1
      • Remove the motherboard assembly from the front cover.
      • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
      Ask FixBot
    1. DualShock 3 thumbstick replacement, Input Board: step 10, image 1 of 2 DualShock 3 thumbstick replacement, Input Board: step 10, image 2 of 2
      • Carefully push the two vibration motors out of the input board frame.
      Ask FixBot
    2. DualShock 3 thumbstick replacement: step 11, image 1 of 1
      • Lift the input board assembly off the motherboard.
      Ask FixBot
    1. DualShock 3 thumbstick replacement, Motherboard: step 12, image 1 of 2 DualShock 3 thumbstick replacement, Motherboard: step 12, image 2 of 2
      • Pull both analog stick covers straight up off their joystick posts attached to the motherboard.
      Ask FixBot
    2. DualShock 3 thumbstick replacement: step 13, image 1 of 1
      • Use a soldering iron to de-solder both vibration motor wires from the motherboard.
      • Don't have too much experience with soldering? Check out our soldering guide for detailed instructions.
      • The positive (red) wire connects nearest the top of the motherboard.
      • When soldering on circuit boards, be sure not to overheat the connection as permanent damage may result.
      Ask FixBot
    1. DualShock 3 thumbstick replacement, Thumbstick types: step 14, image 1 of 3 DualShock 3 thumbstick replacement, Thumbstick types: step 14, image 2 of 3 DualShock 3 thumbstick replacement, Thumbstick types: step 14, image 3 of 3
      • Depending on the controller model, the thumbsticks may have a different number of pins.
      • There are models with 4 pins
      • and models with 3 pins.
      • Additionally, the thumbsticks come in different sizes. The smaller thumbsticks seem to be used only in models where the thumbstick is not soldered.
      • Therefore, check how many pins your controller's thumbstick has before purchasing replacement parts. The 4-pin version seems to be somewhat harder to source.
      Ask FixBot
    2. DualShock 3 thumbstick replacement, PCB types: step 15, image 1 of 2 DualShock 3 thumbstick replacement, PCB types: step 15, image 2 of 2
      • Depending on the controller model, it may be necessary to desolder the thumbsticks from the PCB.
      • The first image shows the soldered version, and the second image shows the unsoldered version.
      • Depending on which version of the controller you have for repair, go to the corresponding step.
      Ask FixBot
    3. DualShock 3 thumbstick replacement, Thumbstick (soldered): step 16, image 1 of 2 DualShock 3 thumbstick replacement, Thumbstick (soldered): step 16, image 2 of 2
      • The pins of the thumbsticks are inserted through the PCB. Turn the PCB over so that the USB port is facing you.
      • Depending on whether you want to replace one or both thumbsticks, you must now desolder the following points.
      • For the 4-pin version, desolder the points marked in red in image 1.
      • For the 3-pin version, desolder the points marked in blue in image 2.
      • It is also possible to desolder the thumbsticks using hot air. To do this, you must clamp the PCB somewhere with enough space to pull the thumbstick out downwards. Heat all solder joints evenly by moving in circular motions over the solder joints.
      Ask FixBot
    4. DualShock 3 thumbstick replacement, Thumbstick (not soldered): step 17, image 1 of 3 DualShock 3 thumbstick replacement, Thumbstick (not soldered): step 17, image 2 of 3 DualShock 3 thumbstick replacement, Thumbstick (not soldered): step 17, image 3 of 3
      • Remove the rubber that presses the pins of the thumbstick against the input board.
      • The thumbstick is held in place by four legs. Try to straighten these legs as much as possible to release them from the plastic.
      • If you have trouble straightening the legs, you can also try to cut them with pliers. For this, it may be necessary to remove the plastic caps on the sides as shown in the last image. To do this, insert tweezers or a similar tool from above between the thumbstick and the controller and pry it away.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
Jade is helping us fix the world! Want to contribute?
Start translating ›
Sontha
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 137
Past 30 Days: 475
All Time: 2,073
