Introduction
Use this guide to replace the plastic trigger buttons. The #2 trigger button has an attached internal spring.
Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
Pull the black plastic trigger retainer slightly away from the front cover.
Pull the #1 button out of the front cover.
