Installing DualShock 3 Input Board
  1. Installing DualShock 3 Input Board, Rear Cover: step 1, image 1 of 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. Installing DualShock 3 Input Board: step 2, image 1 of 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. Installing DualShock 3 Input Board: step 3, image 1 of 2 Installing DualShock 3 Input Board: step 3, image 2 of 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. Installing DualShock 3 Input Board, Battery: step 4, image 1 of 1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
  5. Installing DualShock 3 Input Board: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
  6. Installing DualShock 3 Input Board, Motherboard Assembly: step 6, image 1 of 1
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  7. Installing DualShock 3 Input Board: step 7, image 1 of 3 Installing DualShock 3 Input Board: step 7, image 2 of 3 Installing DualShock 3 Input Board: step 7, image 3 of 3
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  8. Installing DualShock 3 Input Board: step 8, image 1 of 2 Installing DualShock 3 Input Board: step 8, image 2 of 2
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  9. Installing DualShock 3 Input Board: step 9, image 1 of 1
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  10. Installing DualShock 3 Input Board, Input Board: step 10, image 1 of 2 Installing DualShock 3 Input Board, Input Board: step 10, image 2 of 2
    • Carefully push the two vibration motors out of the input board frame.
  11. Installing DualShock 3 Input Board: step 11, image 1 of 1
    • Lift the input board assembly off the motherboard.
Past 24 Hours: 12
Past 7 Days: 47
Past 30 Days: 216
All Time: 45,095
