DualShock 3 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. DualShock 3 Battery Replacement, Grab your Controller: step 1, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    2. DualShock 3 Battery Replacement, Grab Pliers, and a Philips Screwdriver: step 2, image 1 of 2 DualShock 3 Battery Replacement, Grab Pliers, and a Philips Screwdriver: step 2, image 2 of 2
      Ask FixBot
    3. DualShock 3 Battery Replacement, Turn Over the Controller: step 3, image 1 of 1
      • Easiest Step Ever!
      Ask FixBot
    4. DualShock 3 Battery Replacement, Unscrew the 5 screws in the back of the controller: step 4, image 1 of 1
      • The screws are located in the holes of the in the back of the controller. (The holes are located on the left, and right controller hand grip, and the other hole is located between the left and right triggers)
      Ask FixBot
    5. DualShock 3 Battery Replacement, Take off the Backplate: step 5, image 1 of 1
      • If you have already taken out the screws the back-plate will lift up easily, whilst lifting gently push towards the triggers of the controller, to bypass them.
      Ask FixBot
    6. DualShock 3 Battery Replacement, Taking out the battery: step 6, image 1 of 1
      • Lift up the battery, and move it away from the motherboard(the green board). Next you need to grab your pliers, and grip onto the piece of plastic that the wires lead to, be sure not to grab the socket that holds this plastic piece, and don't grab the wires. Once you have it you should slowly wiggle the plastic piece out of the socket.
      Ask FixBot
    7. DualShock 3 Battery Replacement, Installing the new battery: step 7, image 1 of 1
      • To install the new battery, all you need to to do is grab the plastic part of the battery with your pliers and insert it into the socket that the old battery was in, make sure that the plastic piece is in all the way.
      Ask FixBot
    8. DualShock 3 Battery Replacement, Putting back on the Backplate: step 8, image 1 of 1
      • It is a little hard to put back on, but not impossible. You need to put it on over the R2, and L2 triggers, then you should push down on the back plate till' is snaps into place.
      Ask FixBot
    9. DualShock 3 Battery Replacement, Screw in the 5 Screws: step 9, image 1 of 1
      • Once the 5 Screws are tightly screwed in you are done with the replacement of the battery.
      Ask FixBot
3 other people completed this guide.
Noble Foley
218 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,144
