DualShock 3 Analog Stick Covers Replacement
  1. DualShock 3 Analog Stick Covers Replacement, Rear Cover: step 1, image 1 of 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Analog Stick Covers Replacement: step 2, image 1 of 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Analog Stick Covers Replacement: step 3, image 1 of 2 DualShock 3 Analog Stick Covers Replacement: step 3, image 2 of 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. DualShock 3 Analog Stick Covers Replacement, Battery: step 4, image 1 of 1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
  5. DualShock 3 Analog Stick Covers Replacement: step 5, image 1 of 1
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
  6. DualShock 3 Analog Stick Covers Replacement, Motherboard Assembly: step 6, image 1 of 1
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  7. DualShock 3 Analog Stick Covers Replacement: step 7, image 1 of 3 DualShock 3 Analog Stick Covers Replacement: step 7, image 2 of 3 DualShock 3 Analog Stick Covers Replacement: step 7, image 3 of 3
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  8. DualShock 3 Analog Stick Covers Replacement: step 8, image 1 of 2 DualShock 3 Analog Stick Covers Replacement: step 8, image 2 of 2
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  9. DualShock 3 Analog Stick Covers Replacement: step 9, image 1 of 1
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  10. DualShock 3 Analog Stick Covers Replacement, Analog Stick Covers: step 10, image 1 of 2 DualShock 3 Analog Stick Covers Replacement, Analog Stick Covers: step 10, image 2 of 2
    • Pull the analog stick covers straight up off the joystick posts attached to the motherboard.
Past 24 Hours: 20
Past 7 Days: 119
Past 30 Days: 443
All Time: 122,897
