LG 27UK850-W Control Board Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
127
All Time:
6,096
Comments: 7
7 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide describes how to replace the control board for the LG 27UK850-W monitor. It takes about an hour and a half, with the bulk of the time and difficulty being opening up the plastic monitor housing.
Tools
    1. LG  27UK850-W Control Board Replacement, Control Board: step 1, image 1 of 1
      • This is the control board and housing that we'll be replacing
      Ask FixBot
    2. LG  27UK850-W Control Board Replacement: step 2, image 1 of 1
      • Plase a soft cloth like a towel on a clean, flat surface. Take the monitor off the mount place it on the cloth with its face down. Unscrew the four screws that are located in the mount area.
      Ask FixBot
    3. LG  27UK850-W Control Board Replacement: step 3, image 1 of 1
      • Next, pry open the plastic case. This is by far the hardest part and takes about an hour when done carefully. The bottom edge is the easiest. Stick a metal spludger in the seam between the black and white plastic. Bend the spludger handle down so that the white plastic piece is forced outwards.
      • Work your way across the bottom of the monitor. There are 10 clips in total that need to be popped out.
      Ask FixBot
    4. LG  27UK850-W Control Board Replacement: step 4, image 1 of 2 LG  27UK850-W Control Board Replacement: step 4, image 2 of 2
      • Now comes the hard part. The remaining three edges are fastened with inward-facing clips, which means they can only be opened by pulling the tabs towards the edge of the monitor.
      • Due to the shape of the tabs, each one is easier to open from one side than the other.
      • For the tabs that run along the sides of the monitor, it's easier to pry them back if approached from the bottom of the monitor.
      • For the top of the monitor, it's easier to pry the tabs on the left half of the monitor if approached from the left. It's easier to pry the tabs on the right half of the monitor if approached from the right.
      Ask FixBot
    5. LG  27UK850-W Control Board Replacement: step 5, image 1 of 1
      • Unscrew the three screws fastening the control board to the screen.
      Ask FixBot
    6. LG  27UK850-W Control Board Replacement: step 6, image 1 of 1
      • Open the cable connector housing by gently prying the two tabs on each side.
      Ask FixBot
    7. LG  27UK850-W Control Board Replacement: step 7, image 1 of 1
      • Disconnect the four cables connecting the control board. Be sure lift the black plastic flap on the flat ribbon cable connector before removing it.
      Ask FixBot
    8. LG  27UK850-W Control Board Replacement: step 8, image 1 of 1
      • Everything is unscrewed and disconnected. However, the control board is still attached by a thick gummy adhesive. Firmly lift off the control board and it'll separate from the adhesive cleanly.
      Ask FixBot
Dylan S
212 Reputation
1 Guide authored
7 Guide Comments
Is it possible to re-connect / solder the usb-c port back onto the board? My usb-c port disconnected from the control board.
Matt McCrorey - Reply Share
I am not sure. I have never disassembled the control board housing to see how the USB-C port is attached.
Dylan S - Reply Share
I'm very interested to know if you've given it a go as I will be doing so next weekend otherwise it's time for a studio display haha
Edison Chow - Reply Share
I have a scratched screen. Do you know if the screen has a separate film? Would this disassembly allow me to access the screen and determine which replacement to get?
Die Google - Reply Share
Hi there. I am wondering where the T-Con board would be located on this monitor. Is it integrated into the main control board you are replacing? Or is it hidden somewhere else? Any info at all would be helpful. Thanks so much!
Matt Coon - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 127
All Time: 6,096
