DualSense Controller V5 Middle Trim Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
107
All Time:
845
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Follow this guide to replace the middle trim on a Sony PlayStation DualSense V5 controller.
Tools
    1. DualSense Controller V5 Middle Trim Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller V5 Middle Trim Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Controller V5 Middle Trim Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller V5 Middle Trim Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
Spencer Day
206,558 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 107
All Time: 845
