How to Fix a LACK 22x22 " (55x55 cm) IKEA
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. How to Fix a LACK 22x22 " (55x55 cm) IKEA, How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 1, image 1 of 2 How to Fix a LACK 22x22 " (55x55 cm) IKEA, How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 1, image 2 of 2
      • Place the table on a flat surface and make sure it is not slanted.
      Ask FixBot
    2. How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 2, image 1 of 1
      • Bring the table upside down.
      • You can see a hole on the other side of the table.
      Ask FixBot
    3. How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 3, image 1 of 1
      • Insert the tip of the screw into the hole of the table.
      Ask FixBot
    4. How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 4, image 1 of 2 How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 4, image 2 of 2
      • Rotate the leg piece clockwise.
      • Hold the leg piece in an erect position while rotating.
      Ask FixBot
    5. How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 5, image 1 of 1
      • Rotate until the grip is tight enough.
      Ask FixBot
    6. How to Fix a LACK 22x22 " (55x55 cm) IKEA: step 6, image 1 of 1
      • Repeat the same steps for rest of the three leg pieces.
      • Make sure the grip is tight.
      • To reassemble rotate the leg pieces counter-clockwise.
      Ask FixBot
To reassemble, follow these instructions in reverse order.
Marzuka Suhaima
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 135
