HP Chromebook 11 G6 EE Wi-Fi Card Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
56
All Time:
709
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide assists in the replacement of the Wi-Fi card in an HP Chromebook 11 G6 EE.
Tools
    1. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Remove keyboard screws: step 1, image 1 of 1
      • Remove the screws from the bottom case.
      • Two M2.5x8 PH1 screws.
      • Six M2.5x6 PH1 screws.
      Ask FixBot
    2. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Remove keyboard: step 2, image 1 of 2 HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Remove keyboard: step 2, image 2 of 2
      • Use a plastic opening pick to release the clips that secure the keyboard.
      • Clips are present around the entire assembly. The ones near the hinge are especially tight.
      • Laying the screen open as flat as possible may ease access to the hinge-side clips.
      • Avoid too much prying force. If you pry too hard, you'll break your pick. The trick is to get the pick in just a little bit, and then run it along the edge of the device.
      • DO NOT use metal tools for this step.
      Ask FixBot
    3. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Disconnect keyboard: step 3, image 1 of 1
      • Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
      Ask FixBot
    4. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Disconnect keyboard: step 4, image 1 of 3 HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Disconnect keyboard: step 4, image 2 of 3 HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Disconnect keyboard: step 4, image 3 of 3
      • Disconnect the keyboard ZIF connector
      Ask FixBot
    5. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Disconnect touchpad: step 5, image 1 of 2 HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Disconnect touchpad: step 5, image 2 of 2
      • Disconnect touchpad ZIF connector.
      • Now you can remove the keyboard assembly completely.
      Ask FixBot
      • If your replacement keyboard came with touchpad and cable, you can start reassembling the computer now. If you need to retrieve the touchpad from the old keyboard, keep reading.
      Ask FixBot
    6. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Remove touchpad: step 7, image 1 of 1
      • Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
      • Lift the touchpad out and place into new keyboard.
      • Be sure to evenly tighten the touchpad screws during reinstallation. Even a small variance can lead to a touchpad that feels "off".
      Ask FixBot
    1. HP Chromebook 11 G6 EE Wi-Fi Card Replacement, Wi-Fi Card: step 8, image 1 of 1
      • Use a Phillips #1 screwdriver to unscrew and remove the single screw that secures the Wi-Fi card.
      Ask FixBot
    2. HP Chromebook 11 G6 EE Wi-Fi Card Replacement: step 9, image 1 of 1
      • Gently pull the Wi-Fi card horizontally away from the socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 56
All Time: 709
