Droid Ultra XT1080 Charging Port Replacement
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: step 1, image 1 of 1
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: step 2, image 1 of 1
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: step 3, image 1 of 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: step 4, image 1 of 2 Droid Ultra XT1080 Charging Port  Replacement: step 4, image 2 of 2
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: step 5, image 1 of 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: step 6, image 1 of 1
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: step 7, image 1 of 2 Droid Ultra XT1080 Charging Port  Replacement: step 7, image 2 of 2
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: step 8, image 1 of 1
    • To fully replace the charging port you need to desolder the port and solder a new one in.
knoyes
785 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 862
