Drill Master Heat Gun Motor Replacement
  1. Drill Master Heat Gun Motor Replacement, Motor: step 1, image 1 of 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Motor Replacement: step 2, image 1 of 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Motor Replacement: step 3, image 1 of 3 Drill Master Heat Gun Motor Replacement: step 3, image 2 of 3 Drill Master Heat Gun Motor Replacement: step 3, image 3 of 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Motor Replacement: step 4, image 1 of 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Motor Replacement: step 5, image 1 of 1
    • Remove the metal casing and fan cover from the fan unit.
  6. Drill Master Heat Gun Motor Replacement: step 6, image 1 of 1
    • Bend the metal prongs backward that connect the fan motor to the plastic cap.
    • Bending the brackets too far back can cause the brackets to break.
  7. Drill Master Heat Gun Motor Replacement: step 7, image 1 of 1
    • Remove the plastic cap from the motor,
    • This will allow you to work only with the motor and fan.
  8. Drill Master Heat Gun Motor Replacement: step 8, image 1 of 1
    • Remove the fan by pulling it from the motor rod.
  9. Drill Master Heat Gun Motor Replacement: step 9, image 1 of 1
    • Remove the two 12mm screws from the plastic fan casing using PH#00
  10. Drill Master Heat Gun Motor Replacement: step 10, image 1 of 1
    • Remove the plastic fan casing.
  11. Drill Master Heat Gun Motor Replacement: step 11, image 1 of 1
    • Remove the metal casing from the motor and insert the new motor in its place.
    • You may have to tug a little.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 22
All Time: 1,461
